new cartilage
  • Thread starter Thread starter teorema65
teorema65
how do I in the casket create or modify an existing cartilage and save it so that I can reuse it '?
Good morning theorem,
Maybe you had to put in the drawing of caia. something is on the online guide.
However to create the cartilage in the 2d or to generate a new model of cartilage?
to change an existing cartiglio I open a drawing and selections edit - background.
you open the background editing mode of the sheet and from here you can make all the changes you need.
or always from the background change context you insert - design - square and cartilage. opens a window where you go to choose the type of teaming you want to use among the macros already present in the cat and all the other options.
as you save a cartilage now I don't remember why I don't have the program under my hand and it's a bit that I don't use it.
Bye.
I would like to create one myself or change one existing one, save it and then go to call it back when I need it.
I was interested in knowing exactly how to save it so that I could reuse it
thanks the same
thanks the same
this was for a solidedge cartilage, but once in catdrawing it is the same procedure.
http://www.cad3d.it/forum1/threads/38275-cartigli1) if someone has a better method, faster, etc... is welcome.
2) for what I know, the most "clean" method would be to remake a macro, like the ones I suggested above, or change the macro from which "fish" catches;
3) for what I know, the background or "background" is, in the substance, a second table "back" the main 2d design. If you save a drawing with your new cartiglio in a cartiglio.catdrawing file, you can always copy it and paste it into your background. I don't know if you can create some kind of "detail" as it was on v4.
thanks the same
Good morning
I think the best system is to create a cartilage in a4 format in edit background (I think you will have to create tables with a4,a3,a2,a1,a0 )
created the a4 format with its cartilage is saved for e.g. with name fa4 then open the a3 format and copy the gi cartiglio
