new sketch constraints nx 8.5
  • Thread starter Thread starter ceschi1959
ceschi1959
ask here the question concerning nx8.5. if the illustrious moderator :biggrin: think of moving it from another side go ahead.
as you know the constraints in the nx8.5 sketch have changed in the sense that you can use the two action>object modes (they tell me typical of ideas) or object>action (the typical nx that appears when selecting an entity outside the constraint geometric command).
first you could activate the constraint geometric command, select entities by holding down the ctrl key, and then select more than one bond.
How do you do it now?
Thanks for the tip.
