new user
  • Thread starter Thread starter 3°minore
3°minore
I am attending a solidworks course, we use 2018.
coming as an inventor of course I find all the "defects"?
it leaves me puzzled the absence of a default well-kept name of keyboard commands.
are very particular (ctrl+8?????!!!?? Do I almost get up from the chair? ).
I think I understand that the user solidworks or makes kilometers with the mouse or arranges to customize, and I find everything strange, it will also be the philosophy of the manufacturer, but you want to put the job done, and done well, and equal for all? Then you can repersonalize it anyway!
by inventor if I press "alt" opens a world, the mouse becomes a supreme.
However I am also following the tutorials done well, eventually if I got used to autodesk I can get used to anything.
do you confirm that the axes of origin are geometries of which I have to forget?
customization is wide.
set the keyboard commands as you want: a 50-key plus all variations with shift, ctrl, alt
with the mouse you have 12 quick movements for environment
graphic shortcuts are customizable
It seems enough
Sure, even for inventor.
that of leaving blank fields by default is a choice that I do not share: If I reinstall, I have to recompile, if I change my posting, I have to recompile. . .a rich and comfortable list by default is an advantage.
nothing serious
I didn't understand the problem.
that empty or preset blank fields can you change them, or would you prefer to invert by memory those default?
There is a copy of the settings that you can also take on the pc in the basement in the samoa islet.
If you are new to the software before complaining would be the case you know it well
"You confirm that the axes of origin are geometries of which I must forget? "
What do you mean by this question?
but yes, of course, I pay license and teacher just to learn.
my observation is that a default precompilataura made well would not remove anything to those who want to customize, but would remove the waste to those who do not have time and want to do it, all here
in solidworks the only geometries from which you can not regardless are plans and origin.
that doesn't mean you can't create aces and save them in the template
I come from inventor where xyz axis is 3 floors and at the point of origin
It's the same thing also x sw, as I believe for all cad. forget about it just no, because everything you go to model will be placed in the Cartesian space just compared to those entities. also other entities that you will possibly add in a template, as it recommended you massive, will be placed compared to those.
This is exactly the kind of advice I'm interested in, before leaving hundreds of parts and then finding myself in trouble. do you take any particular attention?
Sorry, I don't even know what to ask.
I wanted to say, for example, changes in the template you found useful in your experience.
for example for now I find it uncomfortable not to have the axes, but it is only because I am accustomed to having them.
It's better than doing some practice.
depends on the work you're doing and how you handle it.
the template is very customizable and you can set many things. I make some examples that maybe is better.
you can make a template with already set material, set in pounds and pèollici for Anglophone customers
a template with the already set cut distinction, certain colors for each specific function, with quotas without decimals for heavy carpentry work
a template with axes, the file properties with already written the non-variable parts of a commit so that the user should only write the description and name
a sheet template
a template with inside already a body that represents the footprint in which the model must be built
depends on all needs
if you do not have a routine job and change typology, customers, mattresses and what else can suit you also the default ones
I have practically never used axes, although from a purist point of view it would be correct to use them not to lean against more sensitive entities than modifications or deletions such as faces or abortions, but they are habits
Keep in mind that the template imposes it in options>property of the document and that all that is or can be present in the features tree is settable. of course you have to save it as a template
Thank you very much
some aspects are similar to inventor, then I will see precisely according to the requirements as you said.
I try to get used to without aces then for now.
Thanks again and good evening
