new version
  • Thread starter Thread starter lisandrino
lisandrino
Hello everyone
we are using the 2007 version of modeling
now we would like to update and contact 2 ptc retailers
both told us that the program we use no longer exists
the problem is that one said that it was replaced by creo direct
the other said he was replaced by creo parametric who is right?
possible that there is no longer the updated direct version since 2007?
the first, new name: create elements direct modeling 18.1 .... update of the old modeling ....
exact, I add that the update is definitely worth it: already' from v17 have been introduced small interface changes that significantly speed the work.
ok thanks, I wanted to know if there is a trial version x compare with the old
It is true that all the colleagues have told you. a large limit however (x me) is the fact that you can no longer charge assemblies with missing components ( error 337). Now the license is extra charge and I don't know how much it costs honestly.
It's from version 15 or 16 that works like that.
I don't know if it's more scary than programmers or commercial greed...
there should be the new command that stores and shows which file/component missing
but do you mean that string from geek programmers to write in the i/o window? I tried to use it, but the result is not easy to interpret. ...
or did they add a simple box that tells you what's wrong and possibly allows you to bypass the problem?
I don't know. But you didn't want to use if? When you say the loser...:biggrin:
instead of giving me some lagnose, take the cue from this forum to call Mr. Modeling and tell what's wrong.... the (self)critical spirit is what brought Western civilization to the greatest successes. :finger:
Now modelling has been taken by the "dark force" and doesn't listen to me anymore! the first marketing action taken was to eliminate the tool that made the purchase of mm not indispensable
