Kaji
Hello I was asked to change a two-storey pallet lift to which to add a sliding door to the top floor for safety.
since I have little space on my hips, I haven't been given the precise data yet but should be 450 mm, as before I had thought of a telescopic door by elevator, unfortunately they already made the rollers and that of floor enters into the frame of the elevator then the classic door hanging over and guided below can not help to tighten their standard frame or "sacrify" a roller roller; I wondered if it was possible to make the doors of the sliding doors "only hanging" even though I have sincerely never seen it.
As an alternative, I had thought of a kind of storm that climbed from the bottom, but given the available space there would be a sheet that stops less than 2 meters from the ground, that is 1,4 meters above the roller coaster. As the expected height for the parapets is 110 cm, I wondered if to safety standards it was sufficient and also what other shortnesses should I observe for example to put micro position for the sheet, photocell and chain protection sheet that makes the movement?
