non-printing foam nets
  • Thread starter Thread starter tmeinventor
tmeinventor
hello to all
I'm making a presentation with fillings made with foamed nets. ..unfortunately when I go to print or do a pdf in the preview it shows me the retino as model, but when printing the retino disappears
I would like to know if there is a variable or a function to be entangled
also the same file with lt (which does not have the ability to create blurred nets) displays it and prints it correctly
thanks for every sugegrimento
Hi, I tried with mechanical 2008 and 2010, both of them printed my nuance.
This is my test file, try to see if you print something.. .
it was a memory and file size problem...if I did a pdf in a1 format couldn't calculate me the retino...so I made them in a3
the only solution that is found is to print with pdfcreator, but this program from problems because the printing process is very slow and employs a lot of resources despite having an i7 with 6gb of ram. also finished the process I remain engaged almost all the ram.
do you have pdf printing software to recommend? I already use acrobat 10 but the snail nets do not print them.. .
I had problems with dimesions in some cases the pc was stuck in the creation of pdf so I think + of pdf creation software the problem both in the amount of memory used
In fact when the press starts the consumption of ram sketches. never to commit all 6 giga.
probabilmete you having a 64bit system manages better the process... I have only 3 gb and a 32-bit xp
this is certain, when I went to windows 7 x64 the increase of performance to part of hardware was remarkable.
