not recognized arctext selection
  • Thread starter Thread starter mmmmmmmmmmmmm
mmmmmmmmmmmmm
Good morning, everyone.
use autocad 2023 and since I made the transition from autocad 2022 I have a problem with the express tool, especially with arctext:
in the creation phase there is no problem: I just write what I need.
the problem I have when I have to edit and select the text: While in version 2022 I would select it and I could directly edit the text from the properties, now instead, always in the properties, tells me "no selection"... and yet I have selected it!
only allows me to change if I launch the arctext command again and select the previously created text.
I hope to have explained, thank you all
I don't know 2023 in 2022, but modifying the text of an arctext was feasible only through the arctext command, at least until 2020.
an escamotage is to have the open property panel (ctrl+1) and select the actext. in the "contained" part will present the present text. change it and voilà, without disturbing the actext.
