not visible the reflectivity and the cutouts of materials
  • Thread starter Thread starter paoloscorsonetto
paoloscorsonetto
Hello everyone, I wanted to help you in applying materials in autocad 2014. practically when I create a new material and attach it to the object, changing the options on the reflectivity and crops, these I cannot see them on the object to which I applied the material. But I can see them when I make it. Where's the problem? I hope you can help me and thank us in advance
as I am following an online tutorial where the application of the materials to the object is explained and when the value of the reflectivity or the image of the crops was defined, these were immediately visible on the object to which they were applied. I believe that there must be a way to see them before making them, otherwise you would lose too much time before getting the desired result.
Some effects are visible with the hardware acceleration enabled and "advanced material effects = on" is set in the manual adjustment window.
of a glass I can see the preview of transparency, but the reflectivity I see only in rendering.
by curiosity, link the online tutorial.
problem solved :wink:
I found the hardware acceleration and was disabled, as soon as I activated the material I finally saw the reflected light and adjusting the value of the reflectivity changed the amount of reflected light and the shine of the material. always in the "hard acceleration" command I disabled the voice "adaptive quality reduction". Thanks for the clues.
