novo file taking not from the templates window
MARCOC
Good morning .. place an image and I ask you... pressing new file part -assieme-table-presentation (the first thing missing the dwg file and okay) but my question and pressing them...inventor which templates opens?? ? ?
nuovo.webpThank you very much
hello zac69... what you say and just for the idw.. in fact it tells me that it does not find the standard.idw file...while for all others not because my templates are called numerically 000-01 etc...and the files part and together and presentations still open them
Where are you gonna get them? ? ?
In fact, the theory is what I wrote. but in practice not. I deleted all template ipts, but he creates the same part. I have no idea where to go and get the file from which to go. As soon as I can do some evidence.
with the opening method placed in the photo, takes its defaults in the installation path
and not your templates defined in the project path!
(sing)
(sing)
No, I thought about it, too. I deleted both installation ipt templates and those of my path indicated by the project, but if you do a new part it can create the same
inventor will have them somewhere or recreate them in flight.. this is not a problem;
any program can create from scratch its files even without templates .. there is no doubt;
However if you want to work properly, know that you have to select your templates
of the project, only there you have your environment set correctly, customized,
The other method, let him lose!!
In fact I work so, my curiosity was dictated by the question of maroc.
