leonardo-037
Hi, I press that before opening this new discussion I have displayed a lot of posts about epicyclical rotisms also using the "search" function but I couldn't find the answer to my question.
I have to carry out a project for the examination of mechanical design i specifically it is to design an epicycloidal reducer for a transmission of a truck.
After banging my head on several books, dispenses and notes I have to entrust myself to someone who knows how to respond precisely.
the question is as follows: "How do I determine the number of satellites to be inserted in the reducer at one stage? "
design data are:
cin=c1= 950000 nmm applied to solar
#1= 1400 rpm
zsat=z2=20 (exit portatreno)
zcor=z3=2*20+22=62 fixes to the rear frame.
I found on the books that if the number of teeth of the satellites is equal then the solar and the crown must be arranged so that a tooth of the solar gear on the satellite must correspond a tooth of the crown on the satellite.
I also know that in a rotism it is preferable to start from the design of the most stressed wheel that should be the solar in my case (if you give me confirmation on this point I would be grateful)
as I said before on all the posts I found around, the number of satellites was fixed a priori or however on some dispenses I found short hints but of geometric character while I knew that through an analysis of the forces it is possible to determine it in order to have values of tensions on the tooth minors of that limit.
If all my reasoning was wrong, please tell me a procedure to dimensional the rotism?
I hope you can help me.
design data are:
#1= 1400 rpm
