numbering photovoltaic panels
  • Thread starter Thread starter manuelmascaro
I have tried and selected them but in many at the end of the macros there is nothing and he says he has appointed from 1.1. to 1.1.
attach a straw of the file, so I check.
if the blocks bend "pn" and have the attribute how the test worked also here. There's probably qlc not coming back!
If he put in the macro the name a$c38b4161f you're sure everyone is called that?
done everything but it does not work while selecting them. the only mistake I know is when I type blockreplace. . brings an error in the tbl file...
I don't want to give you any more boredoms from... I manually replace the panels.... patience from
Thank you
Good morning.
I have 4200 photovoltaic panels to number with a number of type 1.1. 1.2 etc for the string(understood as a number of photovoltaic panels) 1 2.1 2.2 etc for the second string and so on.
I would therefore need a tool that allows me before or after inserting the "pannello" block to select the elements of the string and numerarli accordingly.
I tried with the tools on the forum but failed to bend them to my needs.
Is there anyone who can help me? ?
Manuel
you can try the macro vba I published here: http://bar-ingegneria.forumfree.it/?t=62364413
