romy
Hello everyone,
I often do multifoil tables
usually recover drawings from old projects and then go to copy the sheets one behind the other in the main file
here nothing strange but the numbering of views goes crazy and numbers are put at home or that I do not understand
also the name of the fury sheet to paste sheets with the same name goes to mess up
I know that it is from maniac but it is possible a macro that can do:
- rename all sheets instead of "sheet1, sheet2 etc" in "01, 02 etc."
- rename all the views of all the leaves in an increasing way from the top true bass starting from 1?
