rabber83
Good morning, I am a siemens nx user for a few days, but I used solidworks for many years.
I created a set of various parts that should be welded, then it should be worked with machine tools.
Now I should create the crude and the finished.
I'll explain better.
1) make the only welded assemblies (grey), without the processing, so as to make its design with the separate components
2) the same together, with the work (finished), and make the mass at the table of the work.
for users who knowsolidworks, this procedure could be done with configurations, in practice it was designed the assembling with all the processing. then created the "grezzo" configuration where the work was suppressed, and the "finished" configuration, where the same were not suppressed. at the end of the drawings you imported the views, and you chose which configuration to display, to quote and insert the component table.
for you nx experts, is there a function that can help me?
Darling greetings.
for users who know
Darling greetings.
