Utente NX
Is there any of you who use nx and in the company bend the sheet by means of cold-rolling?
It's a topic that can interest everyone.Hi.
I know companies that do it and, some of these, I started them again with ug16.
if you want some particular info, please contact me in mp, or if you think the topic may be of general character, in the thread.
Thank you.of similar discussions there are many around,
I summarize the two ways I followed to have consistent developments with my experimental tests.
1) what I called of the 'correct factor' and that uses the baf (bend allowance formula), going to put the parameter k in the same in the preferences of the sm (expression_sm.prt). in the formula that calculates the k is recalled a correction factor that is supposed to be equal to the thickness up to a thickness of 1 mm and equal to the thickness greater than 0.25 for each mm more than thickness.n.b. what is said is good for me because it reflects my experimental data.
2) what goes to call the sheet_metal_material_table.txt table (attached also this), whose position you must specify in the customer default. in SMS preferences choosing material go to the drop-down menu and choose the thickness.
I hope to have been clear and above all I recommend: These values are good for me. what I explain is only where to go to put your values and what method to use.
