nx si blocca!
  • Thread starter Thread starter supertramp
supertramp
I happen almost once a day to have to go to computer resources to unlock nx. in practice I do nothing but from the list of programs running, click with the right mouse and choose ends activity. At this point nx unlocks and asks me if I want to save, cancel the rescue and move on like nothing.
I have a workstation fujitsu, picture 600, disk ssd and 4gb of ram. is not a monster but I think it should not give problems, the so and windows 7 pro sp1 64bit. it happened to me even before with nx 8.0 and continues with nx8.5.1.3 mp2
What could I control or change to solve the problem? :smile:
Four giga bytes of ram are a nice limit.
I'd say that's the problem.
apart from that after a little grinding it should say that ram is not enough, but what says ram peak in resource management?
hi ciciu, in fact they are almost never under the 3.5 gb. I happen to work with two sessions at the same time, but so far I have never seen the signal of insufficient ram. I also do not know particular slowdowns during the work that make me understand that you are about to block. I mean that typical signal when a car works at the limit.
However, even as an investment, I will propose the doubling of the ram, thanks :finger:
8 gb of rams are practically the minimum limit for w7 64.
with 4 gb you can hardly work.
in fact monitoring the use of ram I was at the limit. I added 8gb today and I arrive at 4.5gb in a moment. I hope I have solved thanks again ;)
