ciciu
I don't even work.I had heard that they had inserted the Moldovaflow (easy fill) from version 8.5 and from the bundle mach3 but to me it does not work
Did you solve that?
you have read here. ?I don't even work.
Did you solve that?
I read that if I have mw it is not necessary to download easyfillnx8.5_data.zip because already included.you have read here. ?
At least you tried to download it and install it?I read that if I have mw it is not necessary to download easyfillnx8.5_data.zip because already included.
I within the command, the model (only) is pre-selected; I click the injection point (and he creates the cone); I click apply; nothing; nada; absolute vacuum.
This is a speech that, I'm sorry but since you wrote, I didn't understand.... have you read what I wrote about vc installer (microsoft visual c++ 2010 redistributable package)?...
gtac reports the problem and says to download this file http://download.ugs.com/unigraphics/moldwizard/nx85/easyfillnx8.5_data_1.zip.x regarding the flow analysis introduced in the nx8.5 that does not work to me: the assistance says that easy fill looks for a “sla_3d_systems” license feature and in practice all the machs have it.
while the “nx Moldova design bundle” does not have it.
exists pr#1927158 "run flow analysis requires undocumented presence of sla_3d_systems licensed" fixed with 8.5.2
The problem is, you shouldn't even look for her.
nx 8.5.2 will be available 11 June 2013.
hi user_nx ,gtac reports the problem and says to download this file http://download.ugs.com/unigraphics/moldwizard/nx85/easyfillnx8.5_data_1.zip.
I don't know if it will solve your problem...because maybe your pr has not yet been inserted in the solution center.
I spent a moment here...hi user_nx ,
as written some posts back and as mentioned in gtac, the update of December 2012 of easyfill I installed it.
the problem of easyfill lies in its search for a key that my solt-to does not understand and will never understand.
the pr is not in processing because already decided by siemens to cancel it with 8.5.2
That's what I learned. thank you anyway.
I'll wait for the summer you want me to tell you. It's not the first time.
