bertone86
hello to all, I have a problem, I am making the project of a somewhat complex architecture. I have a building that rises from the ground through a mandatory connection, I have difficulty in making the necessary connection. I attach a section to make you better understand what this is about, highlighting the part that I cannot achieve in revit.
The obligatory element contains a scale of access between one body and the other, and externally the oblique side is based on a step to assist the shows that are made on the cover of the block on the ground.
I hope you can help me. Thank you in advance
