obtain same assonometry of a previously made
  • Thread starter Thread starter dillinetta
dillinetta
My problem is a little particular and I have to make a small introduction before I switch to direct question.
I am doing 3d in archicad 12 of an entire urban area. from time to time I make the render of a series of views (both plants, sections and even assonometrics and perspectives), then, using the engine to render inside also the 2dl (i.e. version only lines without surfaces). This process is aimed at overlaying the two representations so that the rendering of surfaces also has contours defined as a real technical design.
the problem is that every time I look back at the views I find myself having perspectives and assonometry (although little) always different from those previously made, so: is there a way to save a point of view or coordinates thanks to which, at a time distance, can obtain such a view and what to another previously done?
Thank you very much for the attention, and apologize if I didn't explain enough.
just sign the rendering coordinates and return them to the next view for line rescue
Thank you. but do I change the coordinates in the co-ordinated paddle? I theoretically figured out how it works but I don't know how to do... Thank you!
in view/modality 3d view/setting 3d projections update x, y, z, azimuth, sun azimuth and sun height
I don't know how to thank you. . .
Since you are so kind and above all so capable... another big problem I have is with the yield of the hoods.. .
I have already installed the goodies accessories, but the only object I have in the falda accessories is "roof surfacer" and there is no trace of hoods or similar... How to do that?
search in the online guide of archicad goodies and manager addon. have you followed these directions to istallre i goodies?
Yes absolutely...I have read all the other posts about it...and the same thing happens to my colleague who has archicad 11 and has downloaded the goodies for that version.
we practically miss the object that allows us to put the plugs to the bonfires.. .
I did a flight test with one of the goodies and goes following those instructions, I don't know your problem from what it can depend on.
why do you use 3d plugs and not texture?
purtoppo we have been expressly requested to show the volume of the plugs...:confused:
However I send you the screen image I have when I open design/extra design/accessori/accessori falda.. .
I checked. .then the difference is that in the general settings of the object "roof surfacer" we only have the option "standing seam", while in the trial of graphisoft (in the link you indicated above) the settings have a much wider range of possibilities: corrugated sheet, trapezoid sheet, normal tiles, rounded tiles.... I think that's exactly why we have only this sheet and not the plugs...can you check in your accessories that you set for this item?
thank you so much for the infinite patience.. .
Mine is not complete, too. However that is the problem, because in the option we have available, we basically choose that the surface is flat
In fact, I don't know how to do... at this point the only one is to create a type plug for each different inclination of each layer and copy it, paste it, copy it, paste it. . .
but how would you create a coup in archicad or... is it not that by chance you have an object or a link where I can download it?
