GiGa
I am working on a set of about 6000 celebrations (with about 300 parts) with inventor 2013. not a mini set, but not even exaggerated. . .
After a first version that I didn't "dominate anymore" (despite there were no mistakes, it was all completely blocked, like when there are conflicting constraints), I rebuilt the axieme to try to eliminate errors on the constraints that I couldn't handle anymore. . .
fact is that, while inserting the least possible number of constraints, solving the incompatibilities immediately, in short trying to maintain the maximum "cleanness", the good inventor goes into the ball and often, after a reconstruction of the axame or its reopening, it signals me of the incompatible constraints... to solve most of the times it is sufficient to confirm the bond and "magicly" inventor understands that it already worked everything (noious though when there are twenty ties packed). .
Now I'm going crazy to place manual stops with cardanic extensions. . sleeves that are fired miles away (obviously with inverted plans), plans that do not want to align... In short, or I renounce the flexibility of the assemblies (because it can serve something) risking in case of any changes not to update the positions, or keep the flexibility and continue to go crazy trying to align the whole...
Excuse the vent, but does it happen to you, or am I particularly inept?
ps: I exclude an installation problem because I also happened on the old car... But then I blamed the pc...
