offset superfici ed output sezione
  • Thread starter Thread starter pizzaf40
pizzaf40
Hello, everyone.
first of all load the file here, which otherwise can be uncomfortable to understand.
and a model in surfaces. made with proe wf3.
My difficulties are 3:
1) need to make the surface with desired offset, normal to the surfaces themselves, but I can not get it. I thought it was for 90° fittings with a small round radius, but I'd be fine if they collapsed in a corner. How can I get this? all I will need to measure the areas of the various layers and to make point 2.
2) Having the above offset surfaces, besides the size of the area, I also have to lay the surface on a floor (with obvious deformation). This would not be an essential point because I would have someone who does it with other programs, but it bothers me not to understand how it is done and I have no idea. If it's not a long or heavy thing, it's an avoidable explanation... on this I haven't even been informed in the discussions yet.
3) there is saved a section in the file...the section of the piece with the p_01 plan. I would like to find the way to save the only section line (or even the resulting line between intersez) and then save it in drw and do more. I don't know how to isolate her and put her on the table.
Forgive ignorance, but I've always been limited to making a solid model without any other frills, and it's the first time I've been modeling in surfaces and doing other operations... I find myself a little in trouble, and I have no references to understand how to do it.
Thank you very much for any answer.
1) select the entire surface with the surface unions filter and create the offset by applying in the feature options menu with the automatic button the exclusion of the surfaces that could not be offset of that value (see ray on the funnel around the hole)
2) Once the surface is closed and solidified it creates a plan and a series of this and you can turn a thick analysis of its every single floor or set a number of slices to be analyzed. development on a floor of a surface (not sheet) is not possible with... there are specific software that analyze deformed as a phew calculation.
3) the section line is created by making an intersection feature between a floor and the surface. you can hide all elemanti on a level and leave the curve in evidence or copy paste it as a spline and transfer the points directly to a text file.
I hope I've been helpful.
