offset without quota but bound + repeat on curve 2d
reggio
hi, I followed the prampolini tutorials
basic notions - repetition guided by a 2d curve
ref: http://www.youtube.com/watch?v=rgpqjj0o5c4and I wanted to apply the notion to my case: the function is very useful, but if the driving path does not pass to the center of the part or body to be repeated you can have problems: In my case, as you see here http://i46.tinypic.com/2wmgfi0.jpg[/IMG]rounds to be repeated are diam.10mm and also the step is 10mm, but in the curve the step is not respected.
would you suggest me a quick system to get the perimeter offset always on the center without using the odds but by binding it to a point (in my case at the center)?
i.e. if the offset should always pass and stay in the center of my guide (so not at 10mm or 20mm or ...) how could I do?
