but with wf3 you can't take them off. . .save to all I have to increase the thickness of the attached piece from 46.9 mm to 51 mm with ofset I can not do it, use proe w3
How can I do that?
choose and go under edit/removenon-linear linear rays in the corner as I remove them
no there is no function in wf3, it was introduced if not erro in wf4 :smile:I know that the defeature function is not in the wf3 ... however the piece is simple, see a little if it's okay so
Yes, it is an imported geometryno there is no function in wf3, it was introduced if not erro in wf4 :smile:
I deduce since I can't see that the detail is devoid of model tree. . .
Bye!
p-h
