ogp
  • Thread starter Thread starter ceschi1959
hi baskets, are machines that have predictions and defects like all systems.
pregi: absolutely indicated for those who make many reliefs on components with cavities otherwise not detectable with optical instruments except by destructive cutting of the component.
defects: cost (you know that they really cost a lot), limited field of work, the weight that makes it not usable as a portable measuring instrument and the impossibility to use mechanical probes to measure individual points or to obtain boolean with a few clicks.
thanks to the answer,
we have the flash model 300 and I have found very high precision. But I find it very lacking in both data acquisition and output. It is not possible, for example, to get a stl. It is also true that we are not very experienced, and it is an euphemism, in its use. do you have direct news of mechanical companies that use it?
c.
I know of a French company, in Italy I have no idea.
the fact of failing to get a stl is a pretty serious lack. which formats can you obtain/export?
hi and sorry for the delay, I'm involved with 'strix' on this topic so I'm asking for some clarification on everything. a day maybe the technician will come so I will ask better. I take advantage of your experience and I'm sorry if I'm on the vague but for reasons of confidentiality you know can't give such detailed info. we need to measure precision mechanical organs with encumbrances take into account a cylinder of 100 mm for 2 mm height with 0.5 mm details with tolerances of a few cents of mm. what technique-equipment would you feel to suggest?
