open .iam file with notepad
MARCOC
I tried to open a .iam file with note lock and result and a set of these characters (I
|ž%f8lå) there is a way to visulate translation. .
What are those characters?? ?
but the inventor files are binary files? ? ?
I don't think there's a translation. depends on how you write the file.
programs write in the information files. depending on the type of information you can choose to store it in different ways. For example if I have to store only 0 and 1 I can think of condensing the information in bits. or if I have to write text I can write in bytes. if I have to store data like whole, mobile comma, etc. I will use word (two bytes). etc. etc.
of course the file will contain only a set of zeros and uni, which to be interpreted it is necessary to know the size of the basic information package, and its conformation (decimal, hexadecimal, whole without sign, whole with sign, in mobile comma, etc.).
when you open a file with the notepad, which is made to read the text, he will shorten the bits to eight (bytes) and the decimal result of each byte will write it as character ascii corresponding.
if the information had been codified so, as in the case of a text file, I would read something understandable, otherwise, I would read a series of ascii characters without any meaning.
I hope I've been clear.
cad files are usually compressed files, which are decompressed when the cad opens them. to see the content, take 7-zip, and then dx button on the icon-->estrai.
Otherwise you can use a hexadecimal editor, in the past I used it to sew in the files of if.
but above all, what do you think you get from reading the .iam file?
do you think you can find the key to translating a 2012 rel file into an older one?
:36_1_13: old hope...:36_1_13:
Somewhere in the file there will be something that indicates that with what rel was done!
I tried several times, but I didn't find anything, but I didn't know that 7zip could translate it into more readable characters. . .
hope continues....:36_1_11:
no stefanobruno,sto trynd to understand that I asked us in the previous message
"relation of the axieme with the parts that compose it"
