oloap72
hello to everyone, about this problem I read some old posts but despite everything I couldn't get any results.
Therefore, I work with pro-e wf4 and I would like to avoid having to enlarge the window at every opening. someone on the forum advised to act on the open parameter<window>incrementd setting it on yes, following the indications, the window was still open partially. Finally it was suggested to "save this change on the config.pro"... here I began to incarnate myself trying in spite of everything in this way... I opened the config.pro as text document and I added under section * --- display set ---* open_window_maximized yes string, after which I saved, but I got nothing
Could someone please help me?
Thank you very much</window>
