Staedtlerp
Good morning to all,
I have met the following problem in a table lately:
I own two main subaxiemes a and b of which the second (b) is the mirror of the first (a) in the sense that some parts ( 90%) inside are the mirror of the parts of the first subaxieme.
to do this I simply used the symmetry command in the assembly environment and then I deleted the parts (in b) that I did not need mirrors.
in the first subaxieme to I have a part built in sheet metal design environment of which I designed the open view, that, for simplicity, I will call part1. Now at the moment when I am drawing the table of the symmetric part1 which is in b (which is a different piece because symmetrical and not an anniversary) does not allow me to create the open view and gives me the following error.
"The selected solid is null. open view command cannot be applied to the selected solid"
Do any of you know what it means or have you ever had such a problem? ? :wink:
thanks to all in advance
