opening autocad file with wrong language
Giuseppe_90
Good morning. I searched both on the forum and on google but I did not find solution.
I have installed the Italian language pack (autocad ver. 2022), but if I click on an existing dwg the English version of autocad opens. if instead I click on the link that is created, it opens correctly in Italian language.
is there any way to fix (except open the program and then open the file from -> open)?
hi, I had the same problem, when you are looking for the Italian language pack on the autodesk website, this one comes first but it is in English. you have to go down the page and look for it in the list, what you will find is the right one. before installing the new eliminates the old.
when installing a language then you find two versions of acad in the start menu in the autodesk group, you have to start that in Italian, if you have the connection on the application bar you have to replace it otherwise that still points to the English version.
at every start of autocad (with multiple language packs installed) is stored as "language pack" has been used.
If you open autocad in Italian and never use the English version, the .dwg should always open with the Italian version.
following the instructions @graziano-g (change links) and never open the English version, solve the problem.
Thank you. I solved by opening a couple of times below Italian autocad and then opening directly the file screwed the version in Italian.
hello to all, I solved this way:
1) I opened the autocad folder 2022 installed in the computer inside the \programs \autodesk folder;
2) I copied the contents of the "it-it" folder (Italian language pack) within the "en-us" folder (English language pack, I recommend you to make a copy of this folder before performing anything else so you can return to the previous location) by replacing all files.
in this way autocad will no longer open in English
