tecnicoSIP
I would like to know if there is a possibility on sw, selecting a group of parts of a set, to open the respective tables all in one gesture and not selecting one by one.
opening of drawings from joint documents or partsyou can use the open drawing tool to open existing drawings associated with the active part or document together.
when there is more than one open and unsaved design for a model, a message is displayed which requires you to select the drawing to be opened from the open document dialog box.
- The tool is available in the context tool menu and bar.
- you can add the tool to the mouse gestures and assign them of the shortcut keys.
- you can add the tool to the commandmanager or toolbars. click tools > customize > standard commands > and drag open drawing
in a position of toolbars or commandmanager.
- select one of the following options:
- click on file > open drawing.
- right-click the item at the top of the featuremanager drawing tree or any blank part of the model in the graphics area and select open drawing .
- in the joint document, right-click the component in the featuremanager drawing tree or in the graphic area and select open drawing .
