MORENO100
Have patience but today I want to remove several vents from the proe.
for what I know, proe manages the display of axes with the option "show_axes_for_extr_arcs".
I have long decided to set it on "no" to not have all those axes on the extrusion fittings, for my way of working I tend to draw the sketch fittings in the extrusion phase instead of creating them later with the appropriate feature considering it more convenient and correct in the phase of study and less burdensome for the system (for this last consideration maybe I mistaken).
I am not able to recall the relative axes of the arches of a possible asola. Since it doesn't create them, I define them by re-editing the sketch and adding two "points of geometry" to the arches.
I do so from the good old 2001, maybe in the meantime with the change of versions something has changed, you know how to give me some education or just an opinion?
I currently use the wf5 but shortly I will pass to creo2.
Thanks again.
Thanks again.
