opinion
  • Thread starter Thread starter odisseo 18
odisseo 18
hi, I would like to make a small internal mezzanine, leaning the beams on 2 parallel walls.
a masonry wall would be 2,40 cm long high h 195 cm thick wall 30 ( brick 21 holes
characteristics
height: 12
width: 12
length: 25
unit weight kg: 3,00 )
cm in perforated brick
the second would be thickness 18 cm in masonry of perforated h 185 cm
as I have to adjust as I conceive that material I use, the roof is 3,50 cm high
do you want to support the beams and above the floor or do I have to put the mounts to download the weight on the ground?mezzanino interno.webp
a question if I can, a canned beam of 250 cm 100x50x 3 mm . how much can it be loaded as maximum flow in half-carry?
always a similar boxer 190 cm tall how much can it be loaded of tip, type pillar?soppalco schema.webpaltillo.webp
