optimal configuration for wf4
  • Thread starter Thread starter dema
dema
I often have to work with big studies passing through, we have resigned to change computers.
which features must have a pc to turn a set of an automatic stain well.
attached the characteristics of our pcs...
64-bit machine (so you can use a lot of ram and pro/e 64-bit).
motherboard: must be of good quality, have many slots for ram and support the sas discs
ram: 8 gb (I also work with 2 gb on the notebook and I have no big problems but, when the work gets tough, the difference feels)
video card: nvidia picture (I use the fx 3500 from 3 years and 1/2 and it is very well ... however depends on the budget, the fx 4800 is a missile)
hd main: sas 15.000 rpm
monitor: if you can exaggerate, with 800-900 euros take a 30" hp (my brother has it and on the big assemblies is really all another world)
guarantee: 3 years on site ... costs little and anything happens, within 24 hours must be at you and solve the problem.
brand: I use hp as both server and as workstations, and I never had the slightest problem, I had only one problem on the notebook promptly solved.
who uses of the is said very satisfied.
I would avoid make-up brands, if one has to save so much it is worth making a assemble by choosing the components, always however with 3 years warranty on-site.
on another pc I have the configuration described in taglia_5.jpgwell after moving the call you see in detail.jpg It took 5 minutes to zoom in. the computer I had attached before took a time between 8-9 minutes.
so much to make axleieme.jpg la cui bom è 21fe153_ic14026.rarI could have significant improvements. . .
using a 4gb ram on a 32-bit system is entirely useless as 32-bit systems use just over 3 gb, all you put on is sleeping.
64-bit systems are much more efficient.
What kind of graphics card and what kind of hard disk you use on this pc?
a question... or what do you need all those views in hidden mode since there is not even a quota?
generally this type of view is used only if necessary, as it is much heavier to regenerate than a view with no hidden lines.
It's a mounting set I need to recall the casings, screws and sweaters by putting the baloons and what you see are not hidden lines but the frame on which this group is mounted.
being another group I represent it in phantom not transparent.
How would you behave? I could try to put in phantom not transparent only at the end, now I try.
That's how it came out of the store, then I think but correct me if I'm wrong is the single program that can use up to 3gb so I think I have 4 more options to use more programs. if it is not so I will pass as soon as possible to seven 64bit
What kind of graphics card do you use on this pc?
nvidia system information account created on: 02/13/2010 18:18:22
system name: pc-gabriele
[Schermo]processor: intel(r) core(tm)2 quad cpu @ 2.40ghz (2394 mhz)
operating system: microsoft windows view (service pack 2)
directx version: 10.0
gpu processor: geforce 8600 gt
version forceware: 169.06
Total graphics memory available: 1663
dedicated video memory: 256
system video memory: 0 mb
shared system memory: 1407 mb
version bios video: 60.84.38.00.26
Irq: 16
bus: pci express x16
What kind of hard drive do you use on this pc?
3 discs
ide\diskhitachi_hdt725025vla380
who are the slowest part
in addition to everything correctly told me it seems that you have cpu frequency management issues.
you have a 2.4 processor that is limited to only 1.58:sistema.webpHow come? check bios settings.
Mar
3 discs
I'm sorry to say that, but that's how, 32-bit, the overall usable ram is what I have indicated.
geforce 8600 gt is not good for cad applications is a board that works egregiously for multimedia and video games.
for cad systems it is necessary a picture nvidia or, in sub-order, an ati fire gl.
hard disks are a very important component, because when the ram is saturated the system reads and writes continuously on hd.
therefore with a hd 7200 rpm you will have visibly lower performance than a hd sas 15000 rpm.
...video card: nvidia picture (I use the fx 3500 for 3 years and 1/2 and it is very well ... however depends on the budget, the fx 4800 is a missile). . .
I found what I think is your replacement nvidia frame fx 3800 What do you say?
the picture fx 4800 with the price on the site of over 1600€ seems to me too... For now.
Yes, it is.
the figure is however respectable because we talk about 700 euro+iva, but it is an excellent video card compatible with all the parametric cads that are in circulation.
I don't know the theme song. .
sas = serial attached scsi
This is an implementation of the scsi system, which uses a serial communication (such as sata) instead of a parallel.
is the best data reading and transfer technology for hd currently existing on the market.
Currently with 270 euros approximately you bring home a 300 gb hot plug ... I don't know if I explain, if you have two hd twins in raid mode 1 and one you lightning, you can replace it warm without turning off the machine.
Then there are solid-state hds but, I think we have to wait a few more years to become reliable and widely diffused (currently besides there are reliability problems, they also cost a lot of money).
...currently with 270 euros about you bring home a 300 gb hot plug ... I don't know if I explain, if you have two hd twins in raid mode 1 and one will shine, you can replace it hot without turning off the car.. .
is not a problem on our pcs there is no data here are on the server... then in case of breakage of the disk just restore the operating systama.
seems to me that sas compared to sata cost much more to rpm parity or is it not? . . .
they cost more but, they are based on scsi technology and therefore they are all another thing.
generally in workstation environment (if you have an external backup system) a hd 150 gb is more than enough.
if the project data are instead on the machine then put a few hd in raid1 less performing (they also have 7200 rpm sata) and a sas as the main hd of work.
