I have a question: is there any command to optimize the distribution of an object in a bounded area? to better explain to me, look at the pdf attached.
a specific command I would say no, but using a rational distribution of the silhouettes you can get a saving on the waste material! was that the target?
maybe generating a texture with your shape, you might see something like filling on the sized plate, or group genres and develop them with the serial command on your slab. I don't know what's the fastest!
try to attach the shape and size of the sheet to fill, which I do a test and tell you how you should operate. Thank you.
the fact is that I often deal with these problems and clearly with different figures ... I therefore look for a method that fits with the shape of the object and the area where to insert it.
attached an example thrown down to the flight.
ps: with the serial command I do not optimize because I could also optimize by turning the object to frame it to the best!
