AlessandroC.
Good morning to all,
as from the title of the discussion, I cannot copy in a precise position a sketch within a geometric group "unordered".
I try to explain myself better. . .
- all geometric elements (lines, surfaces, unions, etc.) can be copied and glued to a precise location of the logical tree. "copio" the reference object, "select" the voice of the logical tree to which to queue the copy, "neck" and everything works.
- only for sketches, following the same procedure, the copied sketch is placed at the bottom of the geometric group on which I defined the work object, even selecting an object to which to concatenate the copy.
Of course, in a second moment, I can move it to the desired location.
I wanted to know if I'm wrong, or if there's an option to copy the sketch like all the other objects.
the file works equally, but I would like to give a visual structure to the geometric group to allow all colleagues to understand the order of design operations.
thanks to those who will give me some indication
