orientamento
  • Thread starter Thread starter solarlord
solarlord
Hello, everyone.
can change default display?
I explain, for example, sometimes when I click, on isometric vis, it shows me on the side that I do not want.
I tried wheel with tren, but when I have assemblies I can't turn anything anymore.
or when I look perpendicular to a surface, okay the view is perpendicular but if I want to turn it 180° I can't?
Hello and thank you
Hello, everyone.
Hello and thank you
if it is only to "turn" the display uses arrow keys. from System options > view you can change the "angular steps" by putting the value you want in the ranks box.
then the arrows try to use them in combination with the keys alt, ctrl and shift.. see the resulting effect:biggrin:
Marco:smile:
Staff online
