original surfaces
  • Thread starter Thread starter tega1
tega1
good morning to all, I have this problem: I imported a 3d file in igs, proe I care a feature where inside there is a set of surfaces. I would like to copy some surfaces and make them original (not shredded) I tried with extrapolating function but when I do ok does nothing.
Can anyone help me?
select the surfaces that interest you, then do "modification-> copy" then "modification-> special paste"
hello thanks to the answer, but I tried how you told me but I can't.... .
I attach image of my situation: I imported an igs file in fact in the tree you see the feature.
I cover the surface that interests me but then it does not give me special copy again from the copy and then it allows me to make special copy, at this point I am in the situation of the photo but none of the options allows me to make the original surface (without trim).
I had not understood the fact of trim (however he thought about it max) :biggrin:
