over autocad
  • Thread starter Thread starter Mauromz
Mauromz
Good morning to all
After learning autocad 2010 in the building industry I feel the need to improve the 3d. I would like to learn a new program and I do not know if to turn to 3d studio or rhinoceros for modeling and rendering 3d . I communicate only that I opted in a first time for the 3d studio 2013 composing well 2 bookstores (one mondadori l'altra apogeo) to learn it. something begins to know but the two purchased guides are worth little and are very approximate and confused. Can anyone recommend anything? Thank you
What for? What do you do mostly?
I take care of apartments plants and also have larger projects to which I make renderings. that sincerely with autocad do not satisfy me much. but aldila of this anelerei to build or medella of the vehicles to inherit in the renderings. Thank you.
for the building industry there are specific software, revit, archicad etc.
then you can make it directly with these or refine with software like 3ds, cinema4d etc..
if the technical design doesn't interest you, you can go directly from autocad to 3ds, 4d cinema etc... or model directly with the latter.
What guide did you buy?
I bought a guide of the mondadori "autodesk 3ds max 2010" (confused, bad) and a guide of the apogee "3ds max per l'architettura" (sbrigative for granted many concepts) both bad. Thank you.
I was learning the first rudiments of poser 3d, but I don't know if it can be compatible with your needs
Why don't you try to make autocad 2017? I think it's not bad. I'll give you an example of making that I made with the latest version of autocad.scacchiera-completa-xSito-header.webp
