overlap line center
  • Thread starter Thread starter nunzio1981
nunzio1981
Hello everyone,
I am running in the representation (in drafting) of holes that to quote them you need to introduce the center line, the center marks, to which the lines of demarcation of the sections are added. These objects are all indented lines that often overlap, have different formats, so it happens that in pdf generating you see a continuous line obtained as overlap of these lines. How can I get out of it by making a "clean" design?
Hello everyone,
I didn't realize much. when I create views, or sections, details and so on, I remove the flag from 'create with centerline'. In this way I go to put only the symbols I need getting a clean design.
I hope I helped you.
hi I didn't mean that, if in a view I have two holes that pass through a halfway where I want to do a section, I find myself three lines tract- tract overlapping but that would serve me. having different format appears as a continuous line and you create confusion.
Unfortunately in this case I can't help you.
