ownership management in dft
  • Thread starter Thread starter sbronzo79
sbronzo79
I wanted to ask for information.
in the office we manage the cartilage by means of ownership management, I created a new property and I added the value you have to assign in the faile txt, but within the property management I can not activate the drop down menu of the relative column. . .
Does anyone know anything about it? ? ?
Thanks
search the archive using "propseed" as a keyword, you should find the information you need.
If you put it new, the old files will not appear. However to integrate these entries you must once edited in the file propseed.txt open the various par-psm-asm templates and the file properties go on customized and add the name, type and value item. save the templates and the game is done.
to integrate voices even on already done files just open a set, insert an empty template and property management you will be able to see the new custom property and add it, at this point you just make a copy/paste on the whole column of other details that do not have it and then saved. once you delete the blank template, this way you will be able to integrate new information even on previously created files.
