Good morning
I added a column in the list of those available in the property management to add it in the separate parts table. Now his cells are gray and doesn't make me edit them.
how can I make them white (published) so that I can insert the value I want?
I opened the "management property"
right button on the first gray line
from the menu I selected columns
from this menu I fleggato la parola "lamiere"
pressed ok
pressed ok
You should assign a custom propie to one of the parts of the assembly: Once you do this and save the part, you should see this property among those available in property management and you can fill it up for all members of the insurance. I don't know what it's for.
