pack & go failed
leggera
Good morning.
until a few days I could do the p&g quietly now I don't understand why he doesn't run it anymore.
I have a assieme/table father then the various children with relative tables.
The main axieme opens it normally without errors.
when I go to p&g in the first phase when I search for .ipt files and .iam subassiemi all ok, when I do the second research or I want to attach the tables also fails and find nothing.
if I do the same procedure as a subcommittee instead it works.
only from the main group fails me. Strange thing.
I don't know other inventor features beyond the window that appears to me during the execution.
Do you have any idea what it can be?
there to there I would look if in the prinpal axieme there have been model / configuration of position / active susittutes, other does not come to mind (use the p&g once every two years so I don't even know if these my indications are sensible. . )
none of these features are active.
They're not even big.
I don't want you to have run the file, but it does on 2 axiemi it seems a bit strange.
Are all files migrated to the current version of inventor?
after failure is there a log file?
Good question.
to be all up-to-date files must be opened and saved with the saved command all right?
I did this .ipt and .iam saved at 2024
But as far as the tables are concerned, should I open them one by one and go up with inv 2024?
What's the point of migration?
on catia solidworks sti problems were not there.
I was right now on the page you suggested to me, but I'm not in command:
There's no way to get him to enable the operation.
What stress...
But if a user doesn't have a password, should he put it?
Complete migration and pack & go went to good end.
However, to go and attach the sub-axial boards, I have to let them search by selecting sub-folders where the sub-axis are.
last time if I don't remember the same pack&go had done it complete even with tables only by selecting the main axieme folder by going to search them in the subfolders.
Boh!
