paling on distinct
INVENTORMUSTDIE
Good morning, I can't understand why (sometimes, on some .idw) on the distinct does not display the paling that I did on the drawing. so to check if I put down all the numbers it touches me to print the distinct and check out by hand. Where am I wrong? I've put it in "existing structural."
Most likely the idw is the saved "copy" of another similar previous idw where you reassociated the view. However if you do not score them as balls is because the pallinated view is not the same reference file of the distinct. delete the list parts and recreate it by selecting the view that you have balled, you will see that everything returns.
thank you for the answer. the file was new, as well as the axieme from which I made the views. By deleting and releasing the list parts did not change anything, the design was on "foil1" and if I put them the distinct it made me right. But I wanted to put it on "foil2" and repeated the error (always selecting the axieme with the file search button). then I tried to select the main view from the tree diagram and put down the right distinct. so I think that inv associates the ball to idw views and not to the axieme that you select on list parts. Thanks again for the suggestion, made me find a solution. Hi.
