pallinating verification
  • Thread starter Thread starter Login
Login
Good morning.
I happen to check or change the tables made in the past; They are usually assiduous by a hundred pieces and sometimes I have a problem with the balls. we assume that the distinct contains 100 components, but only 97 balls are present, perhaps because they are eliminated and no longer replaced. Now as now I go to select every single line of the distinct to highlight its ball, but clearly this takes me so long.
Is there a faster way to solve this?
Isn't that maybe he picked up your repetitive components?
I think there is an option, during the creation of the table, which allows you or collect the parts, and to put a bubble only by component, or to leave it complete, and to put all the bubbles even if repeated.
At the moment I can't tell you which option is because I always use the form collected.
I use a quick trick in this case:
-I insert out of cartile a 3d view consistent with the bubble table (same simplified representation if it was used)
-I insert bubbles automatically for view:
--if the bubbles there are all, the program returns the message that all the components are branded
--if some bubbles are missing, the system puts them and selecting them, it is highlighted by the system to which component they refer, at that point I decide if only to move them automatically, or manually move the point of the bubble line.
Can someone tell me what concept I create decides the order of the balls?
depends on the table on which the ball rests, on my goes in order name of the component file, put on a very narrow column and very small text, not to show it (visible there is drawing code, description, quantity and other parameters
