Marco F inox
I made a drawing in scale according to your measurements, speculating the 80 quota you did not indicate and that it is to check.
as seen from the leverages, the ab piston, is too close to the c and d points, so it must make a considerable effort, force that in most part discharges on the bearings, as I had already said.
the quota 159 and also decreased the quota 546.
It is necessary to approach as much as possible to two equal odds, taking into account that the piston shortens and therefore less will be its parade.
the piston is too long.
