parallel tolerance
  • Thread starter Thread starter Federico Scussat
Federico Scussat
Good morning
Could someone clarify the meaning of the modifier on parallelism tolerance in the attached sketch?
Thank you in advance
from anywhere you mix 100mm you will have to respect that tolerance.
the edge has no relevance
If I mix 100 mm from one point to the centr of the plate must be respected the tolerance per hour I imagine for example.
I do not understand the difference between indicating 0.008/100 and simply indicating 0.008 in this case.
If you have a plate of 1000 mm long you will understand that it changes a bit.
