clafan
good afternoon to all, this is the first time I write in a forum and I would need your advice.
I have to make a pocket with size 275x150 deep 160mm. on steel reclaimed 2311 , I am thinking of using a brake iscar to inserts (torco r. 0.8) diam. 50mm for the roughing, the question is: someone would know to indicate turns and advances for this type of milling so that the insert has more possible life? Thank you.
