dario__3
Hello everyone I am in the condition of having to model different components in a parametric way as they are produced in different configurations. between the various combinations what changes mainly are the measures. Now my first approach was to model the axieme in multi-body environment to manage a single data table. All right until I had to avoid a tree in a view of the asses in the section being sampled... also going into the separate cut and applying the property isfasteners to the only body the body remains sampled in the table. Now I wonder if there is a way to manage parametric models together with only one table without going to configure from time to time the various components in the axieme. Moreover it would be very interesting for me to be able to change the scale of the sheet or view according to a consistent size of the modeled component. I'll explain. I have component that has dimensions that can vary from 100 mm in diameter to 600 mm. Obviously for legibility issues the larger components go in a1 with a 1:2 scale, the smaller components I would like to make them stay in a1 but in a different scale and I would like the scale to be set automatically with an instruction. according to you it is possible. of course the solidworks version I use is 2015
Thank you and soon!
Thank you and soon!
