part families
  • Thread starter Thread starter MaiMollare
MaiMollare
Good morning
I just created a simple family table without any problem. a piece with 3 extrusions. in the family table I have 3 a-b and c components where extrusions disappear once at a time. everything ok and verified.I would like to create now 3 views in the drawing, inserting first the piece to then the b and finally the c.
where can I set the component of the family table to make it appear in the way you want in the table?
have been migrated from release 8 to release 12 for a few days. first with the same problem I arranged with the layers and refs. set. I wondered if with the 12 can be avoided.
Good morning
are components or parts? i.e. part family do it with the assemblies or with the features?
If they were three parts or three non-part family assemblies would be the same? Is the problem in part family or design?
Can you explain this?
Okay, I try to be clearer by making you another example.
when I worked with creo parametric I created a generic of a screw with l=10 within the family table
then another screw called a with l=20, b with l=30, c with l=40 etc. with the due differences worked in the same way with nx12.
When I came into the table and put in the view of the vine I could a priori decide which screw to insert by choosing it between that of the family table. I wanted to know if there was this option in the release 12
Let's see if I can help you: with nx you physically create the parts as a file, unlike creo (which I don't know for which if I said a cable correct me).
whether you work in master model (drafting separated from the model) or drafting in the model itself, you have the option to choose which part to put on the table and which side view. This has always been. so if the part comes from a part family or not it does not matter.
I'm trying to explain it to you with this image.
Hello baskets
in creo parametric select the father (which would be generic) and then you have the option to select the son you want and put it in the table, always working in a single file. That's the advantage, but if I understand nx that doesn't like it.
I solved this way I created my family table. then I inserted the father into another model as if it was part of a set, so it allows me to select the components of the family table I prefer and solved the problem.
Unfortunately after 12 years of I create thinking in certain way I get automatic. However, nx12 compared to version 8 I used made a big leap forward and is giving me so much satisfaction.
Hello and thank you
