lelebianconero
Bye-bye.
I've got a little problem with part lists that I can't really get through with.
It's probably a stupid mistake I keep committing but I can't figure out why.
I created my set that I'll call pippo.
I later created a new pippo-dwg set where I imported pippo and made the table.
pippo is composed of 20 parts, where 3 are assemblies (i.e. pieces mounted together) and the remaining are defective (4 washers, 4 bolts, etc.)
I insert the part list but something that leaves me quite puzzled:
the 3 assemblies are displayed correctly, but for the rest I get one line with inside the symbol [...].
I tried to select one at a time the washer, bolt and nut elements and if selected individually report the attributes in the correct position.
if I try to select only two of these, the counter is correctly updated but in the cell where I find the description or the part number appears [...].
even more incredible that in the supplier column this is always present and never becomes [...]Tell me where I'm wrong?
Thank you very much
Thank you very much
