part specchiata
  • Thread starter Thread starter snake779
snake779
Hello, everyone. .
I have a problem with mirrored parts...if I on an original side do its
mirrored and then I want to make changes only on the original but without bringing it back to the mirror as I have to do?
make the original with a configuration. make a second configuration with the modifications on the particular "wrong". make the mirror of this configuration
But it's okay to me in the second mirrored table, in the cartiglio, it takes me the code of the right side, instead it should take the left code.. .
No, if you can handle it. if the mirror is made with a configuration it is sufficient to fill out the specific configuration properties. if it is an external part it will be enough not to keep the properties connected with the dx model of origin.
but then the left configuration should be done on the right file. and in the left axieme must always insert the right file with config, sinsitra? I always put the right base inside the two right axioms and only sinsitro with the two config, relative? I don't like it, doesn't it go to the left axieme the physically left base, with its file?
there are several methods to make right and leftist. I use configurations almost never because I want a separate file to manage in the pdm.
exactly... remains the fact that the left table does not take the left code, but remains the right. .
Have you tried to change the data here?1675351163092.pngor depends on the order in which you entered the drawings1675351806529.webp
