part-surface union
  • Thread starter Thread starter murdok
murdok
I'm learning from you. . .
I use catia v5, for exercise I was asked to "design" a sleeve...I got in part design a base and then in generative shape design I made the filling tube, I gave thickness to the surface and hidden the latter...and here arises the problem, as going to collect me from 2 edges therefore error....:eek::finger: I do not know if I have been clear,what d'
It would take an image... with the tree open to see your sequence... reading seems confused.
I can't understand how you used the workbach, if your resulting thickness is a surface, or you created a superfice solid.
Perhaps, the problem is simply because the offset you created, does not touch the base and visually do not notice.
